- Grit_dogTrailblazerIf you have to ask, then it's probably a job for a bus shop.
I'd look to see where I could get a porta power type ram or jaws in by the mounts to lift or rotate the engine just enough to RnR the mounts.
Never put engine mounts in a bus before. - Tyler0215ExplorerDo you have a way to lift and support the engine while you do the replacement?
About RV Newbies
