nuget102 wrote:
Sprayed a can of sea foam and it helped with the stalling quite a bit. However, when I moved it the other day (it was over 100) it kept stalling. I'm guessing it was overheating, which I kinda expected. I think I may need another can or two of sea foam but like I said, it starts a lot freaking easier and doesn't stall nearly as much.
Also I'm on a phone so drag and drop... not an option lol. Currently no wifi.
I'll be sure to change the fuel filter and what not. But at the moment my main worry is getting one of the two generators running.
If its carburated motor you might want to check all ruber hoses for cracks and subsequent vacuum leaks..
Also adjust the choke when the engine is cold!
