alishlosh
Apr 25, 2014Explorer
donn0128 wrote:
Your budget, or rather lack of budget is going to be your biggest hindrance. For 6K an 80's or maybe a early 90's vintage is about what you can expect. And at that age there is going to be problems. Things like the roof may need replacing, tires for sure, fixing wood rot is a definite possibility. Not to mention appliances that no longer function. Unless you can up that number to at least 10K you are more than likely going to be throwing good money after bad chasing problems.
Yeah, that's basically what I've been looking at, 80-90s. I've found some fairly decent ones, but none that fit me perfectly. I'm also a lot more concerned about stuff like the engine, transmission, and internal parts in general. Because I don't know much about the internal operation of RVs. And those are the things that can end up putting a person is the hole thousands and thousands of dollars. Would you recommend getting the newest one I can possibly afford?
About RV Newbies
