diazr2
Aug 07, 2016Explorer
I hear the eco boost is a nice truck. But with a 150 you will be restricted to the size. I would guess if you are going to live in it full time you would want something that is roomy. I would much rather spend time in my own trailer rather than a motel room that's for sure. Your first starting point is to see what your truck can pull and yes there are all kinds of weight ratios for the same truck so you need to check into that first thing. Good place to start is the sticker on the inside of the drivers side door. and then go from there. Other than that you are just spinning your wheels. Find out how much you can pull how much you can carry and most importantly how much you can stop.. Then you can narrow your search accordingly.
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
