swanny297
Jun 21, 2014Explorer
westend wrote:
Both of the trailers you've looked at will be too much weight, once loaded, to meet the payload requirements. The hitch weights will have you over the limit.
Please explain.
2703WS - GVWR 7750lbs, dry hitch weight 549lbs (with WD 67% = 367lbs)
2809W - GVWR 77560lbs, dry hitch weight 701 (with WD 67% = 469lbs)
According to the bodybuild sheet my max trailer weight is 8600lbs and I haven't exceeded my payload. I understand there will be additional payload but the trailers also have cargo capacity - I think between the those 2 I could safely pull either of those trailers.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
