catkins
Jun 27, 2018Explorer III
NO- you will have no power to your electrical outlets from the battery. I am a CPap user and have a 12v adapter that can connect to a battery or can be plugged into a 12v outlet. You will need some way to recharge your battery if staying for more than one night. You cannot use your humidifier on your Cpap while using 12 V.
We boondock long term but have a solar system and four deep cell AGM batteries. Be aware that you cannot deplete your battery more than 50% without doing long term damage. A small portable solar panel might help you recharge the pop up battery.
110 degree heat would be a NO GO for me. You will have little relief from the heat and even a fan moving hot air does not help much. You could buy a small inverter to charge the phones but again, need a way to recharge your PUP battery.
Wow, good luck but I am skeptical of your comfort, health and happiness in attempting what you have described. Be safe!
About RV Newbies
