time2roll
Feb 22, 2017Nomad
You only need one maintenance charger. If you get a small one then yes plug the RV in 8+ hours to give a charge before you set the battery on the maintainer.
Using a larger 5+ amp maintenance charger is fine also.
I would avoid low cost trickle chargers. Get quality such a Battery Minder or Battery Tender brands.
About RV Newbies
