wanderingaimles
Jul 05, 2019Explorer
For three days, you can pretty easily modify your behavoir enough to get by with minimal equipment changes.
Learn to use Navy showers to minimize water consumption.
You have a Genny so plan to use it for a couple hours morning and evening to charge your batteries. You wont get back to 100% but if you get back to 90% after the first night, and to 80% the second night, you will be good for that third day.
You will want to get 2 good batteries, and no, a group 27 rv/marine is not a big battery. Either go to a pair of group 31's or better yet, a pair of GC-2, 6 volt batteries wired in series will give you much more usable power.
LED lights will help a lot, reefer use on propane uses minimal electric power for its controls, so use it.
Furnace is a hard user of 12 volt power for the fan, but are you planning ski trips with the trailer? If not evenings in the 40's to 50's are not that had to get through, set the thermostat back to 60 or a little less overnight, and use an extra blanket.
Summer use with a need for AC is the one that is difficult, Batteries cant do much for that unless you go huge.
Try a trip in the fall when temps are moderate, and then decide for yourselves how far into winter you are comfortable.
About RV Newbies
