pianotuna
Jul 12, 2019Nomad III
How about tucking a 300 watt inverter near to the battery bank and running some light cord to it? The Victron PSW is sometimes under 100 bucks on Amazon. it weighs in at 7 lb (nice big transformer so you won't be dealing with the vagaries of a switch power supply.
philh wrote:
If you want to run any 120V devices while dry camping and not using the generator, you'll need an inverter. Pure sine wave versions. I wish I had gone with 300 watt, however, my wiring was not up to the load that 300 watts would have put on it. Since I bought it, I've found at least two items I would love to run on the inverter and both are in the 180-200 watt range :(
About RV Newbies
