Golferdude21's avatar
Golferdude21
Newby Dry Camping Questions
Hi guys,
So my wife and I are going to start dry camping. We have a 2007 27’ toyhauler w onboard generator. Most places im seeing do not allow generators 24/7 or are very limited usage if not allowed at all. So planning on upgrading to LED lights inside to start with. And getting a new deep cycle battery cause ours is somewhat old...as far as the fridge goes are you guys that boobdock even using it??? Or are you keeping your meat eggs and such in a yeti/orca type cooler. We only plan on dry camping for a few days 3 at most right now. Dont plan to invest in any solar panels right now. I know well use lights and water pump...how much energy does water heater use. Ours is a pretty standard 6 gal unit, any input is appreciated. Do i need nultiple batteries or can i get away with one big one like a group 27? Or somethin. TIA
  • Your water heater and refrigerator should operate on your propane if your dry camping with a small draw off your batteries for control voltage. Multiple batteries would be better . You could use your generator within whatever the rules are for where your staying to recharge your batteries. You should have enough propane with full tanks for a lot longer than 3 days.
  • Not sure what type of rig you have but won't your fridge and water heater also run on LP?
