drsteve
Jul 12, 2017Explorer
Old-Biscuit wrote:drsteve wrote:Old-Biscuit wrote:
IF you normal water source has a high iron/sulfur content then the water can get smelly
In that case you might want to drain fresh water tank, water heater and hot/cold lines (low point drains) between trips..
Easy to do.....and less involved then having to sanitize or do several rinse/flushes to get rid of smell so you can use trailer.
Just drain it....
Thought NE had some of the BEST water in nation :H
The sulfur smell is caused by iron-eating bacteria that produce hydrogen sulfide gas. The way to get rid of the odor is to kill the bacteria with chlorine.
Or just flush/rinse water heater
Flushing won't remove all of the bacteria. If you don't kill them, the smell can return, even with fresh, untainted water.
About RV Newbies
