2012Coleman wrote:
Chuck_thehammer wrote:
2012Coleman wrote:
Does the barker 42 tote tank have pneumatic tires? If not, get one that does or upgrade it. Also, you don't manually pull it to the dump station, you put the handle on your hitch ball and tow it.
Like this one
YES, the 32 and 42 are pneumatic. ..
I purchased the 32 gallon last month.. but mine came without any air in tires. so a pump is handy. and all the bolts were loose..
good unit.
the hose from the tote to the camper.. I could not assemble it.. (very cheap)... and it needs tote to camper special hose.. not the common hose... camping world and others have this at 15.00 dollars.
I decided the 32 gallon. as my trailer has (2) 40 gallon tanks.
but I am not going to move 40 gallons and the 35 pounds of tote by hand to the truck.
where I am currently camping the dump station is 1/2 mile from the campground, on a public road.. so the better wheels/tires/and grease-able bearing are great. (grease fittings)
Grease fittings? Really? Where did you get it? The one I linked to doesn't look like it would have them.
the WEB photo is like 3 years old... Baker upgraded the wheels/tires .. then the bearings and grease fittings..
I ordered mime from Amazon about 45 days ago... standard item...
4 tires have inter-tubes.. normal tire air chuck... standard size grease fittings.
