NYCgrrl
Mar 12, 2014Explorer
For any one who canna read the link here is the specs and some of the info on the unit:
Standard Equipment
T.O.P.S (Electric Roof with Rigid Side Walls)
Electric brakes
Flexiride suspension
13" aluminium wheels with radial tires
60" X 76" King size bed
36" X 81" front single bed
Two-burner LPG flush mount stove
LPG tank with gauge
Propane and CO detectors
Smoke detector
Front portable table
Cabinet with sliding shelves
Front roof storage cabinet
Fridge 3,1 ft³ built-in LPG and 120 V
30 A 120 V electrical inlet
Converter with 3 step charger 45 A
LED lighting
Exterior light
Two interior duplex ground fault protected 120 V outlets
One exterior duplex ground fault protected 120 V outlet
One auxiliary-battery-powered 12 V outlet (car lighter type)
Fresh water inlet
12 V water pump
60 L fresh water tank
60 L grey water tank
46 L Black water tank
Monitor panel: tanks, LPG and batteries
Fixed flush toilet
Interior shower with curtain
Exterior shower outlet
Toilet wash down spay
Sliding step
Variable speed roof vent
Rear window screen
Door screen
Lateral window screen
Curtains
Rock screen
Fire extinguisher
A revolutionary roof
Its aluminium skin is made from a single sheet, without any joints. It is opened or closed with electric actuators. Its crescent-shaped windows are made from tinted tempered glass. Once closed, the retractable roof creates an aerodynamic shape, which gives the Alto a drag ratio 75% lowerthat a traditional travel trailer.
When the roof is closed the Alto has an exterior height of only 2,10m (83") and can therefore fit nicely inside a garage. Once the roof is opened, the Alto offers highly comfortable living space with an interior height of 2,08m (82"). Its front dinette is usable even when the rear bed is set up. The beds, fridge, storage and toilet are all usable when the roof is down. Two distinct dining areas are available by simply moving the table.
U.S. Patent 7,488,030
CDN Patent 2,580,172
Ultra light, the Alto is entirely constructed from composite materials and aluminium.
The walls and roof are a sandwich construction of a honeycomb core laminated with an aluminium skin on one side and an aluminium or Alufiber skin on the other. Alufiber combines the light weight properties of aluminium with the resistance of fiberglass. The Alto is built exclusively from materials that are water resistant such as aluminium, Alufiber, plastic, Formica and glass.
On the road: With its Flexiride independent suspension system and its very low centre of gravity the Alto is very stable. Its aluminium frame is constructed without any welding, and it supports stream-lined holding tanks designed to optimize the aerodynamics. Equipped standard with electric brakes.
Standard Equipment
Electric brakes
LPG tank with gauge
Smoke detector
LED lighting
Exterior light
Fresh water inlet
12 V water pump
Fixed flush toilet
Sliding step
Rear window screen
Door screen
Curtains
Rock screen
Fire extinguisher
About RV Newbies
