UGL's avatar
UGL
Permanent Residential Toilet Retrofit
Hello all, new here, have a rather unique issue I think.
I recently became a RV live in by choice, no wanting all the space I do not need I opted for a used 32 footer. But plan on getting her onto a permanent pad when construction of my machine shop is further along.
I didn't know what I was getting myself into with the septic system in these things. I currently am "dry camping" on septic and use a portable to dump in nearby house septic system, nasty business that is for me, can't wait for permanent hook up. But I have had some issues so far.
For starter every time I walk in the trailer it smells like someone just passed wind, to my left walking in is the pantry, right on the other side is the toilet room. Occasionally I smell the tanks contents near the bed. My trailer has the master bed in the front obviously, but directly adjoined is the lav and shower with toilet room aside the shower with walk way between them, also hope to get a "bulkhead" or panel wall installed to separate the master from bath.
But my desire is to replace the toilet with a 10" rough in residential (with only 9-3/4" actual rough in) and to drop out the black tank and hard pipe the toilet to existing dump pipe. I don't wish to have to dump my tank twice a week forever, even with a permanent hook up.
Now I have never messed with RV's till now, but I am tech savvy and handy with all manner of tools and machines.
Anyone out there that has experience and or knowledge please help.
Can I fit a 10" rough in toilet in a 9-3/4 rough in space?
Can I easily drop the black tank out with what I think is an insulated underbelly. Of course all I can see is that typical black plastic cover sheet and foam to fill gaps.
Can I easily hook pipe to the underside of the closet flange and plumb that to the dump pipe.
I understand how to remove the tank itself but the details above need answers please.
Thanks-
Bill
  • ScottG wrote:
    The problem is you will be filling and emptying the black tank very often if you use a residential toilet. And you don't want to just leave the valve open if you have sewer connections.
    A working RV toilet should not smell so I think you have something else going on.
    You must have skimmed over all that, I had the intent of removing the black tank when using a residential toilet.
  • on our TT you flip a switch when the tank is full and then after about a min you flip the switch back. It takes about a second to flip the switch and we do it about every 5 days. If you are parked in one spot you don't need to play with the hose only open the valve. The easiest way would be to learn how to use what you have.
  • Cant do it unless you also remove the holding tank and then replumb the waste system. Better solution might be to learn the proper use of an RV waste holding system and dump once a week or so. BTW RV's do NOT have a septic system. They do have waste holding tanks. Proper use generally does not result in odors improper use does.
  • The problem is you will be filling and emptying the black tank very often if you use a residential toilet. And you don't want to just leave the valve open if you have sewer connections.
