time2roll
Jul 31, 2014Nomad
motorcycle jack wrote:
For those who are recommending a power booster: Nothing is free, i.e. increasing the voltage INCREASES the current load on the power pole. P=IE that is power (watts) is the voltage multiplied by the current. E=IR, so the voltage is the current times the resistance on the line. If you want to increase E, voltage using a fixed resistance (your AC and the microwave) then the current goes UP. Now the E has gone up so Power goes up or current increases - you will trip the PMS system much quicker this way so he won't gain a thing!
If the air is running nicely at 101 volts and 14 amps it will slowly overheat and burn up.
If you boost voltage to 112 you might draw 15 amps from the 30 amp supply but your air conditioner will keep you cool running for years to come. And with 112 volts the PMS will keep the power on. Still it is appropriate to run the water and fridge on propane to save power.
About RV Newbies
