Dec 16, 2013Explorer
If it is a diesel, I assume that it runs off the fuel in your "gas" tank. Usually there is a level of fuel in the tank that a generator will not run when below that level. Sometimes a 1/4 tank, sometimes more or less. Make sure your tank is past a half full. Onan generators also will not run if the generator's oil level is low. Check that if there is sufficient fuel in your tank.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
