othertonka
Dec 16, 2013Explorer
Most MH have 2 sets of batteries, one battery or set for the chassis and one battery or set for the "House". Which batteries did you replace? Also most MH use the House battery/ies to start the generator. Sounds like your house batteries are low or dead. use a volt meter to check the batteries, a fully charged battery should read 12.6 volts. If it all checks out you have a bad connection somewhere along the line, maybe a bad ground where it connects to the frame.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
