Veebyes
Dec 20, 2013Explorer II
You said that you are only getting a hum on turning the key, an indication of low voltage. Before running off checking potentially expensive things, start with the basics.
Test the battery. Not just for voltage but on a load tester. Check & clean battery connections & connection at starter. Is the bendix stuck on the starter? Key switch faulty? Solenoid faulty?
About RV Newbies
