bgum wrote:
Not normal. You should not have any leaks. It may be your vent releasing some pressure. If you have filled the tanks and not used much and the temperature goes up the valve will vent. Try using some and then check for leaks.
Also you may have a little trash in the vent valve.
Don't run out and buy new disconnect from tanks and tap a few times then hook it back up and see if you are good to go.
"vent releasing some pressure"
Maybe that's what happened, if that is the design. The air temperature has been rising a little the last week and the tanks are almost full. I'll keep an eye on it. I may try the soapy water check on the connections. Can I remove the cap that says "Do Not Remove Cap" just to do a quick test?
