NanciL
Jan 03, 2014Explorer II
My criteria from long time experience.
At 32 degrees your water won't freeze in your pipes. There is a tiny bit of of insulation that the pipes give them.
If the temp gets down to 27 and there is a high wind blowing directly on the pipes, they will freeze fairly quick. Wind chill is a big factor in how quick the pipes will freeze.
If you leave the water running, even if the temp gets down to zero, they won't freeze.
Jack L
Jack L
About RV Newbies
