Ivylog
Jan 04, 2014Explorer III
The forecast for Monday is 41/17 so you either need to winterize or have heat inside the TT. If you have heat/power I'd take the low point drains out and open all valves plus drain the water heater. Set the Tstat as low as it will go and leave the cabinet doors open. I would put half a cup of antifreeze in your drain traps as they will not get any heat from inside.
For those of us from south Fla... the panhandle is part of Georgia.
About RV Newbies
