Atlee
Jul 30, 2013Explorer II
1) make sure you have a working CO detector. 2) If you have an on board generator, get a Gen-turi. This will direct the generator exhaust up and over the MH. 3) If you have portable generators to use with a TT, just move them as far away from the trailer as possible, and put them down wind as much as possible.
efiguero wrote:
So I've read that it is not recommended to run a generator at night in a motorhome while everyone is sleeping because of the chance of CO poisoning. Is this true? Or is this similar to the debate on how safe it is to run a fridge on propane while driving? I am just curious as I assumed the whole purpose of a generator was to provide electricity to the MH when not plugged in, so if you need AC at night the gen is needed, right? I know in some parks due to quiet times you can't run them at night, but if there is no restriction and you have CO detectors installed in the MH is CO provisioning from your Gen running a common issue?
About RV Newbies
