SolidAxleDurang
Aug 03, 2013Explorer II
Dutch_12078 wrote:boatms03 wrote:
I would not want to add that to my generator. adding that extra 8' or so of pipe will restrict the exhaust. this may cause the generator motor to work more causing premature failure. if you dont believe me try breathing thru a 2' hose then a 10' hose... see which one you can breath all day and night thru.
The Gen-turi only adds a 12" sweep elbow directly to the existing exhaust system when in use, much shorter than most of the exhaust extensions that Onan sells themselves. The elbow is also a slightly larger diameter than many RV generator exhaust pipes. The remainder of the riser is a 3" composite plastic pipe that draws in air at the open bottom to cool the exhaust before it exits at the top. Any difference in back pressure would be extremely small in my opinion and experience.
So it's a very well designed, unnecessary product. Got it.
About RV Newbies
