Atlee
Aug 03, 2013Explorer II
I have a Gen-turi. It most certainly doesn't restrict exhaust. The end of the Genturi is about 3 inches from the end of generator, and is about 3-4 inches in diameter. It doesn't restrict exhaust, but does send the exhaust up and over the MH.
boatms03 wrote:
I would not want to add that to my generator. adding that extra 8' or so of pipe will restrict the exhaust. this may cause the generator motor to work more causing premature failure. if you dont believe me try breathing thru a 2' hose then a 10' hose... see which one you can breath all day and night thru.
About RV Newbies
