TucsonJim
Jul 13, 2015Explorer II
Good question.
On the "black" tank, you should only open it when you are ready to dump the contents. If you leave the valve open, two things can happen. The first is that foul odors from the sewer can make their way into your coach. The second is that solid items such as poo and TP can dry on the bottom of the tank and cause a plug.
On the gray tank, some people leave the valve open until the day before they leave. This will allow some liquid to accumulate so you can flush it out better. Personally, I leave them closed.
Here's the order I dump in:
1. Black tank until completely empty.
2. Gray tank for kitchen until completely empty.
3. Gray tank for Bath until empty.
By doing this, the gray tanks will flush your sewer hose (some people call it the "stinky slinky") and get out most of the yucky stuff from the black tank.
Jim
Jim
About RV Newbies
