lj2654
Jul 13, 2015Explorer
Leave both valves closed(black and grey tanks)...
Depending on how long you are staying somewhere will depend on when you drain the tanks.
You want to keep an eye on your grey tank levels as they will fill fast if showering or doing lots of dishes.
If I am showering I usually open the grey tank prior to....
but you want to have plenty of grey water to rinse your sewer hose after emptying the black tank if you are leaving soon.....
Use lots of water when using the toilet as it will keep solids from forming in the tank from tissue....also will break down solids easier.
About RV Newbies
