wa8yxm
Jul 14, 2015Explorer III
baldyman1974 wrote:
When I hookup to park sewer do I open any of the valves?
Some folks open the gray but my answer is NO, do not.
now.. Some specifics and modifications
Where I am now I'm using a SLUNKY (Tm) sewer hose support so the hose is a near straight line from the elbow under the rig to the elbow into the ground.. No dips, If I leave a valve open sewer gasses will back up the hose and .. Well have you seen those adds for chemicals (Which by the way are a waste of money) showing the stinky RV? Yup, that's what happened.
Closed the gray vale (The one I'd left open) and stink quickly vanished.
The alternative (and this is how Gray #2 is plumbed) is to have a hos that forms a natural "Trap" (Gray 2 (Wash water, no kitchen sink) on my rig drains ia a 3/4 inch GRAY garden hose wich is lying on the ground.. Since both the inlet (RV end) and outlet (Sewer end) are more than an inch above ground (I drilled out th hose fitting on the sewer end elbow) a water trap is formed blocking the stink.
This can be done with a 3" hose too but it takes a much larger "DIP" My neighbor did it that way.
About RV Newbies
