lawrosa wrote:
1. do you have the 3rd seat in back? ( I removed mine when towing to save weight. Makes a difference)
2. Whats the hitch tag say?
3. Whats the max tire pressure say and what lbs?
4. No flex fuel when towing. ( dont know if you use that)
5. Do you have the load leveling suspension with the tow package?
6. On the door tag what does it say for front and rear axle weights?
Hi Lawrosa,
Thanks for your input. I did look up the models you proposed, and the funny thing is that even Jayco lists my vehicle (as long as it has the tow package) as compatible with their smaller series. To answer your questions above:
1. I have stow'n'go seats, so they can't be removed. I suffer a 100lb penalty according to the book.
2. Hitch says 3500 lb max and 350 lb max tongue.
3. Did not look at TP
4. Don't think we have flex fuel up here.
5. Yes, load leveling and electronic sway control were included in the tow group. I slept in the van a couple of times and acutally felt the load levelling work when I moved around back there.
6. Will have to look at the sticker.
