Houndguy's avatar
Houndguy
So...question for you all.
My wife and I are originally from the Pittsburgh area and she would like to visit family there on a regular basis.
We are thinking about getting a Class A or Class B mobile home and letting it sit on some property we own in the area. We are thinking a Class A or B would suite our needs and if we decided to go somewhere else we could.
Here's the thing. We are looking at spending no more than 10 to 20K on this vehicle and have no idea what to look for in a RV.
I'm a monkey with a gun when it comes to anything mechanical so we have to take that into consideration. The vehicle would be sitting for 9 to 10 months out of year at least, and I have no issue with a trailer because of this but the wife wants a A or B class.
So...what do I look for? Ask about? Since were buying used is there anything I really need to know about that I'm missing?
Am I unicorn hunting?
  • DrewE's avatar
    DrewE
    Explorer III
    Why does your wife want a motorized RV in this situation? Are there any plans to travel with it, or just to use it while it is sitting in one location?
    If you're looking for a vacation home, an actual house trailer (of the trailer park variety) would probably be much more satisfactory than most any RV. It would require less maintenance and have more room and quite possibly be better insulated. It would, of course, require water and sewer and electricity at the property, which may make it not an option. Among RVs, a towable is probably more suitable for a fixed or semi-fixed abode than a motorhome, if only because your money and room is all devoted to living space stuff and not split between living space and drivetrain.
    A class B RV is basically a conversion van—a (nice) cargo van with some living quarters built into it. Since cargo vans are comparatively small, this means a lot of inherent compromises: small holding tanks, tight quarters, little kitchen areas, beds that may need to be converted to couches or whatever during the day, that sort of thing. They're much more satisfactory for travel than for staying in one location long-term.
    A class A RV is larger and usually more suitable for longer-term stays, but less suitable for day-to-day driving. A class C is more similar to a class A than a class B in terms of space, generally speaking, though there is a range. (The difference between the classes technically only depends on what sort of a chassis the unit was built using. A class A uses a bare chassis, a class B a van, and a class C a chassis cab or cutaway chassis. Bus conversions are usually lumped with class A's, for better or worse.)
    Any RV requires a good bit of maintenance, and a motorized RV requires more maintenance than a towable because it is both a house and a vehicle. Sitting for long periods—many months—without use or driving is generally not great for a motorhome. If it is to be driven at all, there are tires and drivetrain maintenance and registration and insurance and other similar details to attend to.
  • RoyB's avatar
    RoyB
    Explorer II
    You probably should check with the COUNTY folks to see what is needed to use your RV on your property - Some countys do not allow this... May be permits required too etc...
    Roy Ken
  • If you're leaving it for long periods of time I'd lean towards a travel trailer or 5th wheel. There's just less that will go wrong mechanically.
  • if you are just letting it sit, a small TT makes a lot more sense to me.
    bumpy
