zul's avatar
zul
Solar System Purchase for Weekend Boondocking
Looking for some advice on our upcomming purchase of a DIY 12v Solar System. We've done lot's of research and we are on a small budget. Our frequent trips are usually 2-4 days at a time. We really only NEED to run the water pump, propane detector and a few lights. This totals 6-7 Amp Hours / Day using online usage calculators = super low usage.
Here is the 100W Solar Panel we've decided on. $169 & free shipping:
http://www.amazon.com/RENOGY-Monocrystalline-Photovoltaic-Battery-Charging/dp/B009Z6CW7O/ref=sr_1_1?ie=UTF8&qid=1387034158&sr=8-1&keywords=100w+solar+panel
The Converter in our travel trailer does not work. So rather than replacing it we are going solar. We almost never hook onto Shore Power (dedicated boondockers). So, when we install our little solar system, what will we lose by not having the converter? and will there be wiring problems created by the not-working converter/charger?
Charge Controller: We'll get the best PWM w LCD that we can afford. MPPT is just too expensive:
http://www.amazon.com/Amp-PWM-Charge-Controller-Display/dp/B00FB3OPKM/ref=sr_1_2?ie=UTF8&qid=1387034226&sr=8-2&keywords=30a+charge+controller+with+lcd
We currently have a typical cheapo 35 Amp Hour battery. Could this setup handle:
1. A second battery?
2. A second panel?
3. A real battery with 70-80 Amp Hours?
When finances allow, we would like to expand our system. So overall, would this be a worthy start? How would you expand later? Maybe different start up purchases?? Maybe sell all this and start again with a real MPPT charge controller???
We are soon to take the leap into this little PV solar system setup for $270-$300 and use last years battery. Then a new battery ... then 2 batteries ... and then... and then... EEEK!
And finally, will this small system require a FUSE and/or a KILL switch? Each time you cut and connect wire, you lose some valuable power. But what level of saftey is neccessary?
THANKS !!!
  • Oasisbob wrote:
    Based on your estimated duration and power consumption I really do not see a need.
    Me neither. Perhaps carry another charged battery along.
  • We have two group 27's and we did a weekend trip. We have two fantastic fans that we would run at night. Watched about 1-2 hrs tv. Lights were led and we used them very little. Of course we used the water pump. I was uncomfortable with the battery levels the next morning, so I ran the generator for about an hour. I was afraid of it getting down to 50%. Never did but it was in the back of my mind.
    With that said, I think it's a great idea to have the solar to help out some. Especially in Arizona.
  • Based on your estimated duration and power consumption I really do not see a need. We can do four days easy with out twin group 27 deep cycles and three of thise nights we watch a bideo on our 19 inch flat screen. We may charge batteries with a small Honda EU 1000 if we stay more than four days.Merry Christmas and good luck
