joelc
Jun 29, 2022Nomad
Shut off the water. Let all water run from tank. Spray with silicone. Open and close valve...spray again....let dry.
Then turn water back on.
I do this every month or so. Be sure the rubber seal is clean. You can put on some rubber gloves and feel the seal. It should be smooth. If it is rough, then replace. The Kit, Flush Ball Seal is Sku 9108559082. Mfg. Number 385311658.
About RV Newbies
