Grit_dog
Jun 29, 2022Trailblazer
joelc wrote:
Shut off the water. Let all water run from tank. Spray with silicone. Open and close valve...spray again....let dry.
Then turn water back on.
I do this every month or so. Be sure the rubber seal is clean. You can put on some rubber gloves and feel the seal. It should be smooth. If it is rough, then replace. The Kit, Flush Ball Seal is Sku 9108559082. Mfg. Number 385311658.
He's talking about the water valve...
About RV Newbies
