rhagfo
Jul 05, 2022Explorer III
vicmitch wrote:
Hello,
Been having trouble with my Dometic 310 toilet intake water valve sticking open partially wasting precious water into the black tank, just like to know if how common this, just had the old valve replaced, the new one did not work any better, does Thetford toilet valves have the same problem.
Thanks
So are you referring to the water that sits in the bowl?
If that is what you are referring to it is normal it forms not only rubber seal, but also a water seal.
About RV Newbies
