jarata1's avatar
jarata1
TAIL LIGHTS REPAIR
I just replaced the marker and tail lights on my older travel trailer.Well everything went fine till I did the last tail light.I can get the signal to turn on but no light.Also it seemed to knock out the 4 lights above the trailer and one side marker.
I don't know if I hooked it up right.There were 2 white wires coming out of trailer,and the light itself had 2 white wires I connected them together.Maybe I did something wrong like I said the turn signal works fine.
  • Is the tail light you bought for tail lights and directional lights with only two wires (one power one ground) your missing a wire for directional. Or you need to run a ground wire to the tail light assembly it's self. Try a ground wire from a light assemble screw to a ground on the trailer frame.
  • On mine I think the white are ground the blue are running lights as in tail lights and clearance lights. The stop and blinker I don't remember the color.
  • jarata1 wrote:
    what puzzles me is the turn signal works in the tail light just not the driving light
    Running lights and turn signal/stops have no relationship to the running lights. Totally different circuits.
    A good rule of thumb is if everything worked before I touched it, and it doesn't now, It's something I goofed up.
    I would retrace my steps and take apart those lights you opened up.
  • jarata1 wrote:
    yes
    maybe that's my problem
    Sounds like you shorted out the lighting by tying those two light wires together.
  • what puzzles me is the turn signal works in the tail light just not the driving light
  • So some of your trailers running lights work but others dont? If so it, isn't a fuse.
    The lights are daisy-chained from one to the next. Your missing the connection at one of the lights.
  • where would that fuse be I'm thinking I messed up the ground
