2gypsies1
Jul 29, 2017Explorer III
You stated you'll be living in this for extended periods. Will you be in cold temperatures? Double pane windows will really help with cold and heat. Is the underbelly enclosed to keep the piping from freezing? You're looking at small RVs. You might want to eyeball the amount of stuff you'll be taking with you to make sure everything will fit and won't overload the trailer. An outside kitchen takes up a lot of storage space and you can easily just put a camp stove on a table and have your kitchen. What will you be towing with? If you plan to do remodeling, i.e., taking out the bed... make sure there's nothing important under that bed. Sometimes the water tank would be there.
About RV Newbies
