wa8yxm
Oct 29, 2014Explorer III
Progressive Dynamics makes, basically, 3 units designed for your RV
One is hard wired (This is best)
one is plug in (Portable) this is technically identical to the above but for other reasons gets 2nd place.
One has no LCD display and should remain on the store shelf or hook.
This last one will not protect you in a brown out or a power flicker, the other two work identically.
Why do I rate teh Hard Wried better?
Well first: the portables can grow legs and walk off.. Hard wired, not so easy to swipe in the night.
Second, You are "Overnighting" and "Oh it's too much trouble" V/s it's always there can not be forgotten.
Mine is a portable but (this will likely happen in December) I have an "Install" plan for it. (just a matter of buying a cord)
About RV Newbies
