Hi all. Getting ready to head south for the winter. I was checking wiring to toad from my 2012 f-53 and found that the charge line and no power to it. Tried to check fuse but the book does not tell me...
Two things: 1. So now you have a charge wire for your toad but no brake line. 2. Ford doesn't make wiring harness that some have a charge wire some don't. All the wiring harnesses are the same. Some wires are connected, others left unconnected. If there was supposed to be a charge wire, it would be there.
My guess is most MH don't tow something that needs a charge wire, more then likely they may need a brake wire.
