mikgills
Feb 07, 2016Explorer
trans temperature downhill
I have a 95 Chevy Roadtrek 210 (G30 ext) 4L80 trans. HD cooling and factory aux trans cooler.
On long uphills engine temp and trans temp climb, as expected, but on the downhill engine temp goes down while the trans oil keeps going up (2nd gear). Pulling over and reving up rpms only helps until the thermostat fan disengages. After that i have no cool down and temp remains high. I have flushed the oil coolers (2) and changed trans oil every trip but same thing keeps happening. Did not know about this before adding trans oil temp gauge. trans has gone into limp mode a couple of times before adding gauge (reason for adding gauge), No service engine light. It appears the 2nd gear even on decent increase the oil temp rather than decreases.
Any body else notice this on 4L80 trans? Fan is working as it should. What can be done to prevent the increasing temp? Any experience with this tranny running hot? (95 does not have tow/haul mode). (115K miles)
