Audioa_fan's avatar
Audioa_fan
Tripped Breaker
Later on during our debut trip on our 2001 HR Ambassador, we were at an RV park in Pigeon Forge Tennessee the day after Christmas. We had dinner and I started the furnace. We put in a DVD and got settled down. It was still cold so I plugged in a small ceramic heater in both the front and the back. I wanted it to warm up a lot before bedtime and I wanted to do that more with the campground electricity instead of my LP. 10 minutes later I lost all power. I still had lights since they are 12VDC.
After some investigation, I discovered that a few outlets were still hot but most were not. I checked the breakers in the bedroom and they were all fine. I checked the GFCI under the dining room table and it was fine. I was at a loss. Since I still had AC for the furnace, we decided to go to bed. The next morning I continued my troubleshooting exercise. When I checked the basement compartment where the inverter is located I found there were two breaker/switches and one of those was tripped. I reset it and all was well. Even though they were in opposite ends of the RV, I had plugged both of the ceramic heaters into the same circuit without knowing it which exceeded the 20A capacity by 4 amps. Another learning experience.
  • Glad to hear that you solved your problem. It's kinda life life, it is a lifetime of learning experiences. When we quit learning we cease to exist. It sounds from your posts so far that you are really learning your MH. JMT
