tatest
Jun 25, 2013Explorer II
Huskercm wrote:
When the a/c tries to kick on the generators don't throttle up like they should. they do when we use microwave and coffee maker kick on. Talked to Honda and they were not much help.
Stalled motors (like compressor trying to start) look like different loads to the generator controller, compared to electronics or resistive loads. The surge until it starts spinning is way over the combined output of the paired gensets, a surge supplied by the inertia of the rotor of genset (a conventional genset actually slows down briefly as rotational energy is converted to a surge of electrical power).
Maybe Eco mode on an inverter genset means the rotors are spinning more slowly, don't have the rotational energy to give up.
If the A/C starts OK with Eco turned off, then the solution is to leave Eco turned off if you want to use the A/C.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
