Desert_Captain
Jun 26, 2013Explorer III
2oldman wrote:ktmrfs wrote:Perhaps Captain will come back and clarify what he thinks the difference in throttle and rpm is.
the "throttle" will indead (sic) vary by load but the RPM will NOT when not in eco mode.
Obviously you are looking for an argument and as much fun as that would be look elsewhere. tatest and ktmrfs explained the problem (far better than I did), that the OP is having which by the way coincides with my solution. IMHO: The OP's his problem goes away if he leaves the ecco setting in the off position when running his AC all night. Because of the high start up loads of AC which can be far different from most other AC loads this simple solution should work. I hope the OP tries it with success.
2oldman: Congratulations on mastering spellcheck, obviously I need to work on mine, such is the curse of the occasional typo. :R
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
