Effy
Aug 23, 2016Explorer II
I think you have a TT as you didn't specify. Max is exactly that, Max. The best way - and any tire manufacturer will tell you this - is to weigh your RV and adjust PSI (cold) based on the charts from your manufacturer. If you do it to max, your tires heat up, gain Psi which will now exceed max psi. My tires increase psi anywhere from 10-20 psi while travelling (based on my TPMS).
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
