path1's avatar
path1
Valve stems...do the go bad?
Time (or past due) to replace tires that were made in 08. This is on class C. Talking with tire place, tire guy said I should put in new valve stems.
Please don't laugh... I'm really going to have a problem parting with my valve stems:)
When I got this class C I had all the problems with checking air pressure, inflating the tires, etc. Went with couple different systems, of course thay were all supposed to work. Finally spent some time with a tube bender and tweaking the stems just a little and after several trips to a tire "supply" shop (that tire stores buy their supplies from) I wound up with a valve stems that I can use any tire and in any tire position, and best of all no leaks and I can check pressure with wheel simulators on.
(No big secret...Shorty valve extenders on fronts, then a sharp U turn thing, on the rear a long extender that hays nut built in near valve core, and every tire has newer type gator caps, the ones you can thread on other extenders or whatever.) Valve stems are brass color (I assume they are brass, but never put a magnate to them)
So tire guy says I should replace valve stems when replacing tires. When I showed him what I had and it worked, he said I should still replace them "to be safe".
(Talking with wife a dinner last night, she says maybe they get "dizzy" and should be replaced:) I think she was joking (I hope).
Here's the question...besides replacing the rubber gaskets on the stem near valve stem hole in the rim and maybe the valve cores (inside valve stems) what can go wrong? What am I missing? I've never heard of valve stem wearing out?
  • Tvov's avatar
    Tvov
    Explorer II
    If you replace rubber parts and cores you should be fine. Just be ready if the tire shop says that it will void any warranties if you don't let them replace the whole valve stem with new.
    Valve stems certainly do wear out... I've had bad "cores", had the rubber stems just fall apart with age, had them crack, had rust / dirt cause leaks at their base, etc.
  • I would check around and see you can find stems that are already in the shape/length you need vs extensions. An extension while solving a problem is another potential point for a leak.
  • Yes, valve stems can go bad. Conventional wisdom is to put new stems on when you get new tires regardless of whether it's a car, rv, trailer or whatever. Ask about what stems are available and also what extensionns are available to work with your class c.
