westend
Aug 17, 2015Explorer
Gene_M wrote:
Yes, I wasn't sure at first but the OSB quickly absorbed it and it did work it's way through the section, I just poured it on.
Two more ideas I'd like to run by everyone:
1. using 40 mil rubber shower pan liner from home depot under the fresh water pump and tank.
2. putting a 5 zone water leak detection system in.
*Edit - to monitor the hidden areas like under the shower, sinks and toilet.
Any thoughts?
Both excellent ideas.
Some of the problem with RV plumbing is that pressurized supply lines and pumps are located in areas that don't afford easy inspection. You could have a small leak and not know it for some time.
I made the decision when I was working on the Starcraft renovation to replace everything with new PEX and the best fittings I could find. I did a lot of overkill but hopefully, I won't have any damaging leaks.
About RV Newbies
