- 4x4vanExplorer III
Toddupton wrote:
It will work but depending on the filter type you may not be able to replace the filter if it is on its side.
Why not? - AllworthExplorer IIAnd after you drink a big glass of it; you will feel thirsty!
- dave54NomadIt will work fine. The only problem is you get OH2 from the faucet instead of H2O. Just drink with opposite hand and you will not notice any difference.
- tvman44ExplorerAs mentioned , no problem except for when you change the filter cartridge. :)
- TodduptonExplorerIt will work but depending on the filter type you may not be able to replace the filter if it is on its side.
- WyoTravelerExplorerYes, the water is under pressure and will push it through no matter what position. My inside filter is vertical but the one outside lays on its side along side my MH and works just fine. That filter is sealed off at both ends so the water goes and come out the proper places.
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
