Bobbo
Jul 24, 2018Explorer III
jplante4 wrote:JimK-NY wrote:
You are lucky if you still have a water heater that works. Never turn on the heat without water in the tank. Turn on a hot water faucet to be sure the water is flowing.
If it's bypassed, you'll still get water out of the hot faucet.
Note: If you pop the P/T valve to check for water, you will collapse the air bubble and the P/T valve may weep. You will need to re-establish the bubble by isolating the tank, open the valve and drain some water.
The bubble is a design feature that allows for expansion and contraction during heating and cooling.
All you have to do is remove all water pressure from the system, and open the P/T valve. Leave it open till water quits flowing, then close valve. Air bubble restored.
About RV Newbies
