Only_True_Mosno
Sep 25, 2016Explorer
Water Heater Drain Valves..are they worth it?
So I was thinkng of replacing the plastic nut that you remove to drain your hot water heater with one of the brass drain valves by Camco. After reading reviews on Amazon I now am wondering if it is actually worth it?
Comments were that it just trickles out and takes forever to drain it? Also a number of comments about them leaking constantly.
So should I just stick with loosening the plastic nut or go for the drain valve?
