Have you ever heard your water pump running before - they are pretty loud when running. You should be able to tell for sure that your water pump is what is being turned on...
Like all have said above if you connected to CITY WATER you do not need to have the WATER PUMP ON. The WATER PUMP only draws directly from the FRESH WATER TANK to pressurize your water system when you are camping off the power grid and NOT connected to CITY WATER. Although the water pump is designed to run OK without picking up water I would be hesitant of turning on my WATER PUMP if I did not have any water in my FRESH WATER tank.
That is how mine setup works are any rate....
Roy Ken
Roy Ken
About RV Newbies
4,027 PostsLatest Activity: Mar 07, 2025
