CdaddyExplorerJul 22, 2016Water pumpGot all set up filled the water tanks at the gate. Now do leave the water pump on till we leave camp in 2 days or just on when we are running the water. Sorry such a silly question
Sam_SpadeExplorerJul 23, 2016No reason NOT to leave it ON while you are parked and at or near the RV.....since you can hear it when it's running.....probably.Should shut it off while moving though because a leak can drain the tank and burn out the pump.
Related ContentWater PumpWater Pump Failure Traveling To The EclipseWater pumpwater pumpSlow water/noisy pump
