BOB_ElwoodExplorerJun 18, 2013Water pumpI'm brand new. Do you run the pump when hooked up to pressurized water supply?
DavidPExplorerJun 18, 2013Most will not run when hooked up since the system is already pressurized. I know if I'm hooked up to a water supply my pump will not run.
Related ContentWater PumpWater Pump Failure Traveling To The EclipseWater pumpwater pumpSlow water/noisy pump
